FlatSix911
- USA
- City
- Silicon Valley
Reporting that my BH hardtail from BBB also came with the PWX display and the red Yamaha logo...believe that makes it a PW-se.
The bike seems to have arrived mostly assembled, all I did was put on the pedals and handlebars, attach the front brake caliper, then tire air. Seems to be shifting fine, motor seems to work fine.
I am going to take it to the LBS to have them true the front wheel. Is there anything else I should have them look at? This is the first time I put together a bike myself, and I am not sure if there is anything else I need to inspect/assemble.
Congratulations on the new BH... good to hear that you received the upgraded PW-X display and PW-SE motor.
If you are going to the LBS, you may want to also check the shifting and upper and lower stops for the rear derailleur.
Enjoy the ride!
