JRA
I like the way the overall bike weight is distributed better with a front hub. I can still lift the front wheel plenty to avoid man holes etc. and I also like the two wheel drive feature as sometimes I get jiggy with back country loose surface hill climbs
But all in all I find it to work the best for my needs.
I use Schlumpf 2 spd bb drives. V2 is a High Speed 2.5/1 and V1 is 1.65/1 so the 27t rings get bigger. On V1 all the way to a 160" gear which is plenty for pedaling along at 35. You can use conventional cranksets but as you suggest you would need pretty good sized chain rings. I have actually put a Di2 Alfine 11 spd on V2 since the picture was taken which works really well also. Basically as I said keeping the pedal input segregated from the motor drive makes for the most realistic pedaling experience.
I call them HL batteries because that is the initials on the case, stands for Hua Lung etc.... They are all over on Alibaba and China is where they originate it is just who imports them and how you get ahold of one that counts. As mentioned you just want to make sure you have cells that will help with your power requirements.
