stevebriggs
I got my Chameleon a couple weeks ago, but no matter what I do, I seem unable to get the thing to go faster than about 56 kph indicated. I would love mid 60's or higher. The bike accelerates like a Beast uphill. Even limited like that this is a great scooter, but I feel frustrated because it could obviously go much faster. To get to the dealer settings, connect the app to the bike and do a four fingered swipe upwards. Password is akili123. Here is what Daymak say the app should be set at for max. speed:
This are the settings we use to max out our bikes:
Dealer settings menu:
1. Speed limit off
2. Over speed turn on, speed ratio 15, low speed can be 50-80 (this controls speed 1 setting on throttle)
Settings menu:
1. Turbo on
2. High acceleration at 10
3. Low acceleration at 0
4. Battery current A at 80 (this can be higher, but you will get less range)
5. Phase current at 80 (this can be higher, but you will get less range)
6. Battery threshold 74 (this feature should be set 10 below the bikes voltage, The Chameleon default voltage is 84)
These have no effect on the bikes performance:
SHOW MAC on (what is MAC?) ßshows the unique id for the bike
SPEED LIMIT NOTIFICATION 70kph <- this sets when the speed notification will pop up.
The only setting that you need to be worried about is
Over speed ratio, don’t set it higher than 15, depending on the motor it could over drive it.
Voltage threshold. Needs to be 10 below the bikes voltage. Too high values can cause the motor to stall at max speeds.
Battery current a and phase current, too high values can make the motor stall also.
Other settings you can pretty much change to whatever you want.
1. Speed limit off
Settings menu:
1. Turbo on
