I am looking at possibly using a slightly larger chainring on my Sduro Trekking so I dont use the smallest sprocket (11t) on the rear cluster very much, possibly changing to a double chainring, so as not to lose the granny gears I need to get to my home.
The cranks and chainring are marked FSA which clearly is the manufacturer but so far I have not been able to home in on what I need as it has a 4 bolt pattern and a pitch or bolt circle diameter of about 104mm. I have found rings with a 5 bolt pattern and 110mm bcd. Anyone know where more info can be found? Is this stuff Haibike specific? Thanks
