Ohh TPMike... I guess you don't know me or much at all.Little Johnny projecting his anger and jealousy issues once again on this forum, proving my first thoughts on this matter above were spot on......
By the way, my stable of Ferrari's and Porsche's are all outfitted with presta valves. Just because I can.
@6zfshdb: Just between you and me (and not Lil Johnny), that post of mine above was in jest. But don't tell Lil Johnny, I want him to know my Porsche's, Ferrari's and Lambos are all outfitted in Presta's just to elevate his BP systolic and diastolic numbers....
This happens to a Schrader with Dice or Skull valve caps on?I've noticed debris blown out of a Schrader, but never seen that with a Presta ... so the assumption is that the open area of a Schrader valve collects dirt and debris, and I always wonder how much of this ends up inside the tube and causes those strange flats that don't seem to have any obvious cause.
The Presta was invented for thin rims nothing else. But it has turned into some kind of status symbol for wide rims. I probably put over 30,000 km on schrader valves with no issues. I don’t mind new stuff at all, as long as it is measurably better, simpler or more convenient. Presta has not been any of those in my experience. I am now offering a 2 for 1 rim drilling service for Schrader lovers. I’m booked all summer!Why Presta?
- They require a smaller hole in the rim, which improves rim strength.
- They’re lighter, so high-performance wheels don’t need to be counterbalanced for the stem weight in order to spin smoothly.
- They seal tightly on air pressure alone, so there’s no need for a mechanical check valve like on Schrader systems (which can clog with debris).
- They are easily extendable with adaptors, making them ideal for deeper-section aerodynamic rims.
Presta and Schrader Valves Look Similar. The Pump You Need Is the Real Difference
Learn how to tell Presta from Schrader at a glance, match valve length to your rims, choose the right pump or adaptor, and avoid the common mistakes that ruin rides.www.bicycling.com
Presta valves are simply speaking: modern. What would you be contesting next, Fanatic? Thru-axle or self-extracting crankarms maybe?For myself, I'm so happy I could live up the present with its exciting technology available to anybody...
P.S. For the whole youth, I had to cope with Dunlop valves...![]()
I applaud you on your accomplishment. It must have been a memorable day when you conquered the intricacies of the Presta Valve.... seem to require a small amount of additional intelligence to use.
I have two bikes and of course one of each.
Although honestly I've never had a problem with a Presta valve that made me want to get rid of them.
I prefer no valve. Give me those hard rubber tires... no flats... no pumps.![]()
Interesting![]()
Cycling — The SMART Tire Company
www.smarttirecompany.com
Hmmmm, "modern"?Presta valve
