Nothing wrong with checking out your options. Clearly you've learned a bunch!Almost like I should have listened to someone's first post about KT controllers![]()
I'm just curious why they don't have screen connectors?!? Nothing about them I don't like I'm trying to understand why some controller have screen connectors and some don't.I've never used one so I have no idea how you would change anything you didn't like.
I'm not sure I am following?There's nothing about them you don't like as you haven't been exposed to some of the parameters available to you, that can be changed to work best for you and your riding habits - using the LED display.
I generally blow them off as undesirable, but it seems like I've read about blue tooth modules, built into controllers, that allow you to change some of these same parameters. Knowing your druthers here, you may want to do some research there....
Sorry I am not saying I want to use it I was just curious why some have LCD leads and some don't.. I 100% want to make sure it has an LCD lead.I guess I'm coming from the direction of if the controller isn't able to be configured, why use it when there are other options that ARE able.
I am not going to roll the dice that I can locate/buy a controller that has the exact requirements I'm looking for. Wattage vs. speed based cadence sensing for instance......
If you want to try both to see which you prefer, go for it! I'm spoiled, that's just not a variable here.
| Nom. Voltage | 24 - 48V Volts |
| Nom. Current | 35 Amps |
| Peak Current | 50 Amps |
| CAN BUS | Yes |
| Auto Tuning | Yes |
| Sensorless Start | Adaptive |
| IP Rating | IP65 (IP67 with sealed connectors) |
| QC Verification | 100% EOL Test under load |
| Additional Available Protocols | CANOpen, TTL |
It's not available for another 2-3 months their site says unless it's out of dateWhat spec are you looking for?
This controller is 48V 50A, I know you already mentioned ASI is super expensive but I'm very intrigued by this controller.
2BTube
The most reliable sub-compact AC Motor Controller / Inverter available.www.acceleratedsystems.com
