harryS
Yes, you have "Bafang" 9 pin connector. I think Bafang developed it first. Everyone uses it.
You can buy a controller with "waterproof" connectors which will fit the above, or you can buy an extension cable and splice it to your controller.
Many fat bike motors look like the Bafang G60 because they copied it.If you were to buy a true 750W fat bike motor, the 9 pin connector here is too small. It gets more complicated. as they use a bigger connector, which is also copied and can be copied wrong.
Ahicks and I tried a guy who was doing this with a BAM ebike (apparently a blantant copy of the RADRover ...so many copies). Not such a good copy, the alignment marks on the connectors were off by 45 degrees. He couldn't accept that and tried to guess his way with random wire assignments to see what worked. Last I heard, he blew up his electronics and maybe the motor trying to do some unneeded motor wire optimization.
All fun and games until you let the smoke out.
