GuruUno
Trek Allant+ 7 2020 Electric Hybrid Bike
Navy or Silver $3,500 (also in Lowstep)
Allant+7
Product Details
Season: 2020
Code: 59264N
Key Specifications
Frame - Hydroformed Aluminium E-bike frame
Fork - SR Suntour Mobie25, 45 mm travel
Drivetrain - Shimano Acera 9 speed
Brakes - Shimano MT200 hydraulic disc, post mount, 180 mm rotor
Motor - Bosch Performance Line CX, 75 Nm, 25 kph
Battery - Bosch PowerTube, vertical, 500 wh
Display - Bosch Purion
Full Specification
Frame - A high-performance hydroformed e-bike frame w/integrated battery (Range Boost compatible) and Motor Armour, internal cable routing, post-mount disc, 5 mm QR dropouts
Fork - SR Suntour Mobie25, 45 mm travel, preload, rebound and lockout, tapered alloy steerer, 100x15 mm thru-axle, post mount disc
Number of Gears - 9
Shifters - Shimano Acera 9-speed
Chainset - ProWheel alloy
Chainrings - 40T
Cassette - Shimano HG200, 11-36, 9-speed
Chain - Shimano HG53, 9-speed
Rear Derailleur - Shimano Acera M3000, Shadow design, long cage
Bottom Bracket - ProWheel 40T narrow/wide steel, w/alloy guard
Pedals - Not included
Rims - Alex MD35, Tubeless Ready, 32-hole, 35 mm width, Presta valve
Front Hub - Bontrager sealed bearing, 32-hole 15 mm alloy thru-axle
Rear Hub - Formula DC-22, alloy, 6-bolt, Shimano 8/9/10 freehub, 135x5 mm QR
Front Tyre - Schwalbe G-One, 650Bx57c
Rear Tyre - Schwalbe G-One, 650Bx57c
Front Brake - Shimano MT200 hydraulic disc, post mount, 180 mm rotor
Rear Brake - Shimano MT200 hydraulic disc, post mount, 180 mm rotor
Handlebars - Aluminium comfort
Grips - Bontrager Satellite Plus Ergonomic
Headset - FSA Integrated, sealed cartridge bearing, 1-1/8" top, 1.5" bottom
Stem - Bontrager adjustable, Blendr compatible
Saddle - Bontrager Commuter Comp, 165 mm width
Seatpost - Bontrager alloy, 31.6 mm, 12 mm offset
Weight - 21.5kgs (47.3lbs)
Trek Allant+ 8 2020 Electric Hybrid Bike
Red or Gunmetal $4,200 (also in Stagger)
Allant+8
Product Details
Season: 2020
Code: 59210R
Key Specifications
Frame - Hydroformed Aluminum E-bike frame
Fork - Allant+ rigid alloy fork,
Drivetrain - Shimano Deore 10 speed
Battery - Bosch PowerTube, vertical, 600 wh
Display - Bosch Kiox with Anti-theft solution
Full Specification
Fork - Allant+ rigid alloy fork, 1-1/8" steel steerer, 100x15 mm thru-axle, post-mount disc brake
Number of Gears - 10
Shifters - Shimano Deore Rapid-Fire Plus, 10-speed
Chainrings - 40T
Cassette - Shimano HG500, 11-42, 10-speed
Chain - KMC E10S
Rear Derailleur - Shimano Deore M6000, mid cage, 42T max cog
Rear Hub - Bontrager sealed cartridge bearing rear hub, 32-hole, 6-bolt disc, 5 mm QR
Front Tyre - Bontrager E6 Hard-Case Lite, reflective, wire bead, 60 tpi, 27.5x2.4"
Rear Tyre - Bontrager E6 Hard-Case Lite, reflective, wire bead, 60 tpi, 27.5x2.4"
Handlebars - Aluminum comfort
Grips - Bontrager Satellite Elite, alloy lock-on
Stem - Bontrager Elite Blendr, 7-degree rise, 31.8 mm clamp, with mount for Supernova M99 light
Seatpost - Bontrager Approved, 31.6 mm, 8 mm offset
Weight - 20.8kgs (45.85 lbs.)
Trek Allant+ 9.9 2020 Carbon Electric Hybrid Bike
Black $6,000 (also in Stagger)
Allant+9
Product Details
Season: 2020
Code: 59021
Key Specifications
Frame - High-performance OCLV Carbon e-bike frame
Fork - Allant+ Carbon fork
Drivetrain - Shimano Deore XT 12 speed
Brakes - Shimano MT520 4-piston hydraulic disc, post-mount, 180 mm rotor
Battery - Bosch PowerTube, vertical, 625 wh
Display - Bosch Kiox with Anti-theft solution-->I BELIEVE IT IS THE SMARTPHONE HUB NOT THE KIOX
Full Specification
Frame - High-performance OCLV Carbon e-bike frame w/integrated battery (Range Boost Compatible) and Motor Armour, integrated internal cable routing, post-mount disc, 12 mm thru-axle dropouts
Fork - Allant+ Carbon fork, 1-1/8" carbon steerer, 100x15 mm thru-axle post mount disc
Number of Gears - 12
Shifters - Shimano XT M8100, 12-speed
Chainrings - 40T
Cassette - Shimano SLX M7100, 10-45T, 12-speed
Chain - Shimano SLX M7100, 12-speed
Rear Derailleur - Shimano RD-M8120 SGS, Shadow Plus design
Front Hub - Shimano Deore XT, 32h, centerlock disc, 15mm thru-axle
Rear Hub - Shimano Deore XT, 32h, centerlock disc, 12 mm thru-axle
Front Brake - Shimano MT520 4-piston hydraulic disc, post-mount, 180 mm rotor
Rear Brake - Shimano MT520 4-piston hydraulic disc, post-mount, 180 mm rotor
Handlebars - Bontrager Pro Lowriser, carbon, 31.8 mm, 15 mm rise, 690 mm width
Headset - Sealed cartridge, integrated
Stem - Allant+ forged alloy, integrated cable routing, 31.8 mm clamp
Saddle - Bontrager Commuter Comp, integrated light
Seatpost - Bontrager Approved, 31.6 mm, 12 mm offset
Weight - 18kgs (39.68 lbs.) <---I DON'T KNOW WHERE THEY GOT THIS WEIGHT BUT IT IS 51.5 LBS!!!! AND ON BIKERUMOR.COM IT SAYS 22.1Kg which is 48.72 Lbs???????
39 or 48 or 51 anyone really know?
Allant+7
Product Details
Season: 2020
Code: 59264N
Key Specifications
Full Specification
Number of Gears - 9
Chainrings - 40T
Allant+8
Product Details
Season: 2020
Code: 59210R
Key Specifications
Full Specification
Chainrings - 40T
Chain - KMC E10S
Allant+9
Product Details
Season: 2020
Code: 59021
Key Specifications
Full Specification
Chainrings - 40T
