J.R.
Erstwhile
- USA
I want one... I can't afford one, or maybe I don't want to try to justify one! The craziest ebike we are likely to see! A must read! (There aren't enough exclamation points available for this one!!!)
"In terms of its electric drive, the DRT packs a 4-kW motor, a 14-speed Rohlof Speedhub and a SmeshGear transmission. At low speeds, motor output is managed by a pedelec system aimed at maintaining an ideal blend of pedal assistance and battery usage. You won't necessarily want to be pedaling when gunning for the top speed of 43.5 mph (70 km/h), so there's also a right-handlebar throttle for cranking up motor power alone. The motor can send up to 184 lb-ft (250 Nm) of torque to the rear wheel." Read more here.
