Gionnirocket
Well-Known Unidentified Member
- USA
- City
- Y. O.
The pattern never deviates.
Best ever/drowned in metaphor & simile.
I must say I didnt see that one coming, must have been a good vadoThe pattern never deviates.
I sent a PM. Didn't I tell you how to get in? Well it is spelled out in the PM. I thought you already got to the advanced settings.I must say I didnt see that one coming, must have been a good vado
Dude... I'm glad you're excited and that it's working great for you.. But that's how the programming is done.IMPORTANT:
To prevent poor torque sensor performance, ensure the bike has COMPLETELY STOPPED and that your foot is not on the pedal before powering on THE DISPLAY. (From the 2,7 website.)
John,
I will swing by at 3:45 Sun. for the display video demo. It takes two hands. I can dial the angle of crank kick-in, its now at 3 degrees. Everything is so programable down to milliseconds, and each nano-voltage for each sensor in-put. Visitors and fans are fully blown away to the state of total incredulity, a frenzy of disbelief. We will show them and will be assured by documenting it all live. These settings are not the Koran or Bible; cargo moms have different needs than rock garden dads. It is a gravel bike. That is how it is set. Others may vary and should.
PedalUma
Being able to have a longer trailing assist would be useful at times.. Maybe an on the fly push button for getting through tight rocks where pedals strike?Actually the run on feature is baked into their latest software upgrades at certain assist levels for certain motors, I've just seen it mentioned on several platforms.
Problem is that although I have alot of off road motorcycle riding experience I still use the left brakelever for my rear brake and pedal like I always have on a bicycle and so reaching for the throttle while maneuvering underway I don't take time to think about using it and just react with my feet instead. YMMV of course as I know many do depend on the throttle more than I do.
I used to bang my TSDZ2 on logs sometimes also and cringed every time. Only once did it effect me negatively and even then luckily it resolved itself and I was able to continue on my way. But a skid plate is a good idea especially if the motor hangs below the chainring.
The new software is fine? I read somewhere about using a phone to upgrade instead of a PC and cable, but I don't know if that is really a thing yet.https://photos.app.goo.gl/CcsZgZjDA1Tzues18
I made a video. I am not telling people how to setup their systems with values, only that they can play with their settings.
If you cannot view this I will try a different way.
For a premium some displays can be ordered as Bluetooth. I will take a step back for a second to explain something. When you program a display and hit save, it sends that to the controller for a reset. The controller is the size of your thumb tip to the first knuckle. I have not done this yet but once you dial in programing the way you like it, there are ways to then use that to program other controllers to the same specifications. I have the programing cables to do this. Bluetooth to Bluetooth could be fast and easy without cables. There is still so much I do not know.The new software is fine? I read somewhere about using a phone to upgrade instead of a PC and cable, but I don't know if that is really a thing yet.
Regularly on mountain bikes programed for rock gardens, kick-in response is immediate and there is no overrun. They are jumpy. To prevent a pedal strike you can repeatedly move a pedal 15 degrees from horizontal in a pumping motion. That is also were instant engagement hubs make a difference.Being able to have a longer trailing assist would be useful at times.. Maybe an on the fly push button for getting through tight rocks where pedals strike?
Yeah, saving a programing file has been a Bafang feature for like... Forever.For a premium some displays can be ordered as Bluetooth. I will take a step back for a second to explain something. When you program a display and hit save, it sends that to the controller for a reset. The controller is the size of your thumb tip to the first knuckle. I have not done this yet but once you dial in programing the way you like it, there are ways to then use that to program other controllers to the same specifications. I have the programing cables to do this. Bluetooth to Bluetooth could be fast and easy without cables. There is still so much I do not know.
Trying to do that on any type of incline is totally frustrating if not impossible. There's certain climbing situations in which a functional throttle is irreplaceable.Regularly on mountain bikes programed for rock gardens, kick-in response is immediate and there is no overrun. They are jumpy. To prevent a pedal strike you can repeatedly move a pedal 15 degrees from horizontal in a pumping motion. That is also were instant engagement hubs make a difference.
Yeah that push button is called a throttle. And you want a variable output throttle, not a push button as each occurrence can be very different and amount of assistance should be tailored to the situation.Being able to have a longer trailing assist would be useful at times.. Maybe an on the fly push button for getting through tight rocks where pedals strike?
Pedal management via ratcheting with instant engagement works better for me at least it always has even pre e? However the onboard throttle I have could do the job if I ever cared to use it for anything other than taking off and a walk assist.Being able to have a longer trailing assist would be useful at times.. Maybe an on the fly push button for getting through tight rocks where pedals strike?
