Great! No problems with any cables, wires, or brake lines?All done! The installation took about 15 minutes. I have it set to ~60 degrees.
The cables seem to be ok at this setting. I double checked to make sure there were no sharp bends or unusual stress points. As the handlebars moved up I rotated the handlebars to keep them level and that added needed slack.Great! No problems with any cables, wires, or brake lines?
TomBrian, I was not charged tax in Virginia. I've included two pics of my Fomtor adjustable stem, and a stock photo of the standard stem that comes with the Level. I am going to rotate the angle even higher on my next ride as I still want to sit more upright. As you can see from the degree markers I still have a good ways to rotate the handle bars higher and closer to me. I have it set at 35 and can rotate all the way to 90. The 35 adjustment was a marked improvement for me over the stock stem.
I did not have to do anything as I recall. I will take a look at mine tomorrow and double checkTom
I just received this same stem for my Level but couldn't get it to go down onto the frame enough...almost like another 'O' ring was needed. Did you experience this and if so, what did you do? Maybe I didn't loosen things enough to get it all the way down on the frame?
Well, I got it done (not without a lot of effort) and WHAT. A. DIFFERENCE! This will surely make rides much more enjoyable.I did not have to do anything as I recall. I will take a look at mine tomorrow and double check
