This looks like an interesting throttle option. Would this be compatible with the Innotrace (Archon X1) controller?
BAFANG Half Grip Twist Throttle (Right Side). Updated half-twist throttle design that incorporates the full grip.
lunacycle.com
I believe that was one of the throttles shown shown in the ES article.
That the G510 w/ X1 works with a thumb throttle indicates any throttle that works with BBSHD or BBS02 will work.
I'd buy a cheaper twist throttle first (<$20.00) and verify. Reliable information is scant on the net, but I don't hear of problems ... and we would. Loudly.
Another member (Hydra owner), competent with programming the Archon controller, informs me a user accessible 'end voltage cutoff' setting is not there.
So (it works with the thumbie) it's already set. Probably at 40v, the usual default - but it could be 45v, which is correct for a Domino (per factory recommendation). The X1's 'start voltage' setting is available and should be set to 15V.
So maybe (worst care scenario) 30ish% of power available (58v - at full charge) is not accessible to throttle.
This could be a good thing as throttle power can ramp up so fast, having
instant power come on w/ over 100nm is very dangerous.
I'm learning as I go, trial and error, so I make plenty of errors and I made a big one, that I'm in the process of rectifying.
I didn't have e cut-off brakes - or more correctly: I didn't have a front cut-off brake.
With my twist grip throttle on the right side, when I engage the rear brake I let go of the throttle and it returns to neutral.
Very little chance of being on throttle and brake simultaneously and if you are of little consequence as the brake stops the drive wheel.
The right (front) brake is the killer. It's easy to slip up and be on the (left hand) throttle and simultaneously engage the (right hand) front brake.
If that happens and you're on the front brake in a turn, the rear power can (suddenly and with great force) push your front wheel right into a 'tuck' attitude. Worse, an instinct to brake harder (what we do when we start to lose control) exacerbates the effect.
Also, there is throttle overrun, and that can cause this tucking condition.
Understand, when this happens to a competent cyclist they may inadvertently blame a 'sticking throttle'.
It's serious enough, I've stopped using my machine until the Magura MT5e's (not 'e-stop') I ordered for the front are installed.
Now I guess I'll have to interface the brakes with a Domino throttle.
Be interesting to know your results.
