Stefan Mikes
Gravel e-biker
 - Europe
- City
 - Mazovia, PL
How strange, Marcela, isn't it? One might think the rings should be made of steel...
			I was away from biking for a long time. Things change.How strange, Marcela, isn't it? One might think the rings should be made of steel...
Is the length of the bolt the 'unique' part of them? If I had Wolftooth 6mm single ring bolts should they be suitable?Sure. You don't need "Deckas" bolts. 6,5mm length should fit.
They are available in various colours, even in the fasterest red:
1/4/5pc Fahrrad Kettenblattschrauben 6.5 / 8.5mm 8-Farben Aluminum Verschlüsse | eBay
Entdecken Sie 1/4/5pc Fahrrad Kettenblattschrauben 6.5 / 8.5mm 8-Farben Aluminum Verschlüsse in der großen Auswahl bei eBay. Kostenlose Lieferung für viele Artikel!www.ebay.de
5 Stk Einzelketten Ringschrauben MTB Rennrad Kettenschrauben Kettenblatt Bolzen | eBay
Finden Sie Top-Angebote für 5 Stk Einzelketten Ringschrauben MTB Rennrad Kettenschrauben Kettenblatt Bolzen bei eBay. Kostenlose Lieferung für viele Artikel!www.ebay.de
The brand won't matter, except for quality. Wolftooth makes top of the line gear. The length for standard chain ring bolts varies depending on the application; 1x bolts being shorter than 2x bolts. Specialized does use a custom bolt setup for their 1x rings where the rings are threaded to receive the bolts eliminating the need for the standard 2 piece bolt and making service a bit easier.Is the length of the bolt the 'unique' part of them? If I had Wolftooth 6mm single ring bolts should they be suitable?
I was referring to the offer I had linked: 6.5mm for single ring and 8.5mm for double ring.Is the length of the bolt the 'unique' part of them? If I had Wolftooth 6mm single ring bolts should they be suitable?
So your pedals are looking for repainting to match that colour?![]()
Garbaruk has a chainring in matching (?) blue colour which you could add to your collection.I would be forced to replace the blue RaceFace pedals with black Stamp 7...
And of course they have colour matching BOLTS, I presume?Garbaruk has a chainring in matching (?) blue colour
