Supernova m99 pure +
Hey all
I recently bought a supernova m99 pure + for my Bosch cx which requires 12V. Now I found that the night time running light continues to burn with the daytime running light. I had the light output changed to 12V. At first I thought the problem was with the light. However after it was replaced by supernova the same problem occured. Has anyone seen this problem and does anyone know how to solve it.
Best regards from the Netherlands
Mark
Hey all
Mark
Your dealer can disable it. There is an option in the Bosch diagnostic software to turn it off.
7
Thanks for your reply. We have had a close look at the diagnostic software. The only thing we can change via there is the power output which we changed to 12V and if the light should always be on. I also don' understand how I can change the settings for the light via the diagnostic software as only a power cable goas to the light and no signal cable. I fear the problem is with the power output
7
Did you make sure the light ambiance sensor is not obstructed?
We installed it as it came out of the box. The sensor is not obstructed. It also seems to work, as the daytime running lights always turn on during the day. The main light however also continues to burn for some unknown reason. I fear the problem is with the power output from the Bosch cx. I don' t think it is really putting out 12V or not enough amps. I don' know how to solve this.
Greets
