I’ve tried the other day. I can do it this new, to me, way but the top bar on my SL is a bit tall for me. (I’m a bit short for the M I own and tall for the S size frame.) I like your stretching suggestion and will work on it. Being able to mount the bike with a loaded rear rack can be a very useful skill.
I look at it this way . Our hip socket is capable of moving farther lifting it sideways then it is Straight out . My concern with stepping over the bar is getting my leg off and not falling over . Lifting My leg over the back has on occasion gotten it hung up on the trunk bag. But I can balance and get it off without fear of falling . Just saying For me I am far more coordinated swinging . But I can see where Stephan's method would work better for others .
I was just trying to dismount my SL by swinging the leg over the saddle. My shorts got entangled with the saddle and I almost fell! Even if the bike was strongly leaned!
We are all different . I get my heel snagged doing it your way . When healthy I can stand on one peddle and start the bike Moving and swing my leg over . Guess that ability is one thing I haven't lost as I have gotten older . Say are you going to put a suspension seat post on your Sl ?
I had to put a suspension seat post on mine. My butt needed it.
This is your choice! Especially if Vado SL is your only (or main) e-bike, you have the right for more comfort! I'm surprised I have no issues with my rigid SL. But we all are different as Cramer said.
Am still in the state of shock how marvellous new e-bike I've got!
The data have been gathered by BLEvo, an Android and iOS app for Specialized Turbo e-bikes. A shiznit, albeit with poor interface. BLEvo has also exported the ride to Strava. The map was made in Mapy.cz, an excellent free Android & iOS bike route planner and GPS navigation map. I imported a Strava GPX to Mapy.cz, then inserted BLEvo data screens, making a collage.
Thanks Stefan! I have Strava, in the beginning I’ll stick with that and my Apple Watch. I need something very simple to start with to record the rides so I won’t forget. Advanced analysis can come later I think.
I am short at just 5"5" tall, so I got the small frame size on my Vado 3. However, even with the small frame, it can still be a challenge getting on and off, and I am unable to use a trunk bag as I will hit it trying to mount and dismount. I usually use a curb or lean the bike a bit to the side, but as already noted here by others, the bike is a bit heavy and you need to be sure you have solid footing before trying it so you don't lose your balance and fall on the ground with your expensive e-bike. That almost happened to me when I first tried to get on my bike, so I learned that lesson right away. :rolleyes: I am lucky though, because although I am older (63) and overweight, I have full range of motion in both of my legs. I will give your method a try, so thanks for the tip and thanks for the taking the time to make this video.
And by the way, your new SL looks great. I hope you have a long and happy experience with it! 👍
@Stefan Mikes I must just have very limited hip flexibility. Like others here, I have always mounted and dismounted a bike by standing on one pedal and swinging my leg around while moving slowly. I've been doing this all my life and have never fallen while doing it, but recently some doubt was put into my mind about whether that was safe "at my age" (74) even though I ride with guys in their 80s that do the leg swing.
Anyway, I tried your method yesterday on my Vado 4 and can get my foot over if I really kick my leg (not simply lift it), but I can see that I could lose my balance that way if anything catches. In fact, my Crosstrail is similar in geometry to the SL and this morning when my group of guys were going on a ride, I went to get on using that method, lost my balance a bit, and looked like an idiot as I tried not to fall or drop the bike. I didn't do either, but this is not something to practice in front of a group of your friends who start asking what you are trying to do! :rolleyes:
The other thing is that on yesterday's ride I went out to the dealer to talk about getting an SL (5.0 ST), which they don't have and probably won't get for a couple of months. While there, I saw that they had a regular Vado ST so I went to it to see how easy a step-thru might be. To my surprise, it was not much easier than doing it on my non-ST bike! The top tube slants up from the seat tube at a steep angle, so most of it is not nearly as low as it looks from the side. When I got home, I even tried mounting my wife's Trek Verve+ step-thru and that too was not as easy as I expected. The next time we ride together, I'm going to ask her to show me how she gets on and off, but I think it's much easier for her since women are generally more flexible and she also does more stretching exercises than I do (and is 10 years younger).
Anyway, I'm now rethinking the whole SL-ST thing again and might just change my order to the regular SL frame version. That way I can also order the non-EQ instead of having to pay extra for an EQ and then removing parts. I'm going to post a new thread in the forum to get some comments by ST owners, but it sure seems like if a non-ST bike has always worked for me, why try to "fix something that's not broken"?
That's true! SL is a surprisingly small bike. I would have never guessed that by looking at the geometry data. When I mounted the frame L of the demo bike successfully, it made me really thinking, and it expedited my decision of buying the Step-Over SL to be able to ride it in this warm season.
I encourage you to do that. You'd be delighted with the most lightweight version available, and you'll save time and some money, too. There's only the matter of the tail-light that is located under the saddle. If I were in the position of buying the non-EQ, I would have probably kept the Bridge saddle (it is not hopeless), or bought a large Specialized saddle with the padding level of 6 (maximum); Specialized claim all their saddles are compatible. I need to re-iterate that I don't need to replace the seat-post with any Kinekt etc. as the bike is shockingly comfortable without such modifications.
Vado SL and Assistance Levels
Vado SL is very different to its older brother, Vado. Because of its low weight and low power motor, it does not like headwind or uphill rides (because it is indeed more a bike than an e-bike). Of course, riding in adverse conditions requires using more of assistance. I have found a motor setting making Vado SL even more natural and not requiring frequent assistance level changes:
If you ride at, say, 35% of Support and 35% of Max Motor Power, you'll notice even a small incline makes riding the SL harder. I have set the Eco level to 35/70%. Suddenly, my Bike became very very natural and easy to ride. It's because you naturally start pedalling harder on small inclines. Now, the leg power amplification stays the same (35%) but the motor is allowed to use more juice when it is needed. Practical outcome: Easy and natural ride, still low battery consumption.
I very much agree. The 35/35 default setting is too modest. I’m using 40/65 for Eco. More power throughout my natural power range, less usage of Trail which I set to 65/85.
Yes that sounds like same idea I use on the hills. Factory settings on Eco was too low for any hills here so after trial and error I have my SL set up Eco 25/45 Sport 45/70 Turbo 70/100. Not sure why I set Eco Support so low @ 25% might tweak that up to 35% and see if it makes much of a difference. Anyway this way I use Eco for 'OK' hills up to say 12-15% gradient, Sport for most other hills up to around 20% gradient and save Turbo for anything steeper or the days when my legs go on strike!
What I have observed with women mounting women's bikes . The get on sideways . Standing sorta paralel . Kinda like they'd mount you :) They startle the bike . Naturally they step thru getting on and off. But it's a sideways move . Not one facing the Bike like Stephan does in his video. Stephan's way works . But swinging the leg over as you describe is easier. Because that's how our hips were designed to work. Look at little kids that can bring their leg all the way up and grab it . They do that sideways . Like you'd climb a fence . My guess is very few people would do well using Stephan's Method . Although it was an interesting Video . Which also made him seem more human. Especially hearing his version of english :)
What do the two assist levels mean? I don’t have a bike to experiment with yet but the Specialized site just gives the default percentages of assist as one number per mode. Can someone explain the two, as in Eco = 35/50 …
A number of other threads with detailed info, but basically the first number is the percentage of assist (vs the max assist level) and the next is the max power compared to the max power of the bike. So in that case you would have 35% of the max assist level (depending on rider input) but the power would top out at 50% of the max power of the bike.
As I said, search around for a more detailed description with example computations.
In other worlds 35% of the available power up to 50 complete turns of the crank by your pedal power per minute . On a class 1 any % of assistance falls off drastically above that Candance : Definitely at 60 : Cadence in case you don't know is the number of complete revolutions you can do on a pedal per minute . Like a clock from 12 back to 12 . With class 3 you would have assistance closer to the 60 and a larger percentage as assistance goes up . If you can get a class 3 get one . You probably won't use or need the extra 70% of the time. But when you do you'll be glad you have it
