Stefan Mikes
Gravel e-biker
- Europe
- City
- Mazovia, PL
Ya, because Creos are not expected to be walked; and there is no handlebar remote (as I can understand) there.
The Vado SL Walk Mode is the best thought and made option of all e-bikes I've owned. Typical vices of Walk Mode:
- The Walk button is located in the wrong position, or activating the mode is illogical. For instance, Giant e-bikes require that you press the Walk Mode Activate button first, and the + button next: Some idiot at Giant Corp. must have experienced bad nights.
- The Walk mode often requires getting e-bike in motion first (so the speed sensor can detect the motion). The point is: if you need to use the Walk Mode it typically means you are unable to get the bike in motion in the first place!
- Once activated, the Walk Mode on most of my bikes is such it drags you on the flat, so you need to chase your bike; but it works hopelessly uphill. The Trance E+ Walk Mode drags you uphill, which is overly stupid...
It would be too hard to walk the bike up directly from the sand patch visible at the botom. I had to walk behind the tree visible here. It was as easy as an ABC. (In all honesty, my big Vado could climb it in Turbo mode).
Rincon, I live in the flatland, and hitting a hilly single-track is a rarity here@Stefan, you just need lower gears.
