Thanks for that, I understand there are a few teething problems but fully expected, what it is important to do is get the info out there as you have done..... Nobody really knows what is going on behind closed doors.... Anyways let me add one more to the list about the brake lever cut-off switch
- (Link Removed - No Longer Exists)
Hasnain S JafferyGot my bike on Friday and motor doesn't work at all. doing email every day but no response. Condors Ebike has a horrible customer service overall. they never reply you in time and do not communicate. Asked them to call me in every email. but so far no response. What a customer service . <oney down the drain!
18 hrs- (Link Removed - No Longer Exists)
Sondors EbikeHi Hasnain S Jaffery Are you emailing [email protected]? We'll check on this today.
8 hrs - (Link Removed - No Longer Exists)
Michael FortierYou have to adjust the brake cable as it will cut off the motor if the cable is too tight or not adjusted properly. Its an easy fix.
3 hrs - (Link Removed - No Longer Exists)
Bruce Choatethe brake levers have a cut-off switch, if the cable is too loose the switch can be engaged causing no power to the motor. Actually a very common problem, your not the first to have it. https://www.facebook.com/groups/StormOwnersGroup/ if you want more info from over 1700 members.
1 · 3 hrs
