The 12ah battery I use now cuts out via the Battery Management System (BMS) @ 9.36ah. With my 5amp charger it takes about 2hrs to recharge to full capacity. In other words you will never get the full ah stated on your LiFePo4 battery due to the BMS which doesn't allow full discharge of the cells because that would reduce battery life. It is always a good idea to use a watt meter as it will tell you exactly where the battery is at. A Cycle Analyst is the creme of the crop but either the GT or Turnigy will do the job also.
There's a guy here who attempts to estimate real world range based on the following formula:
batteryVolts x batteryAH / 20 = "realistic" range
His opinion is that on average, for the average rider, it takes 20 watts per mile. (This might be a little too conservative, I don't know).
So for my Easy Motion Evo Street the expected range per his formula would be:
(36 x 12)/20= 21.6 miles
Now I happen to know I can get better range than that, but that's the formula he uses. Perhaps on my bike I'm using 16 watts per mile with my assisted pedaling, which gives a range of 27 miles.
He takes great exception with manufacturers that claim what he considers unrealistic range for the average person. He's apparently gotten into it in the past with BH/Easy Motion on this, over that 60 mi range quoted in their marketing material. But, there are people who get this kind of range, and they're not all 100 lb flat road cyclists.
Well, you obviously have not been listening to Bruce Choate. The Sonders bike-properly using the throttle will net you over 50 miles easy. Peddle assist is a gimmick.
Another Indiegogo, but I'm not up for it. No bargain.
https://www.indiegogo.com/projects/add-e-simply-add-electricity-to-your-bicycle#home
Bruce Choate
Price, quality, speed... pick two! Either finish has it's problems.... Gloss finish is faster/less expensive, but getting a good finish can take time. A fast process can create a wavy finish that will look unpleasant. A textured finish, the tooling can be more expensive. With texture you will not see the wavy surface, but the texture will pickup the light different than the frame and that would make the color appear different. Most cheap, mass produced items have textured finish, it gives it a better look. On this bike I would want gloss (even wavy), I thought mixing two finishes of the same color would look like crap! But what do I know I hate the look of the lunchbox to begin with!genuine question Hurley, apart from the typo's.. would there be a reason why it is polished rather than textured? (My guess would be polished / smooth mould would be cheaper than textured, that would add quite a bit more machining I would guess?). also another question, I am not familiar with plastic moulding, do the pictures look like they have come from the (machined) moulds, or are they blow moulded? guessing the little tags on the pieces would tell the story?. just trying to make sure Storm isn't faking it Hurley.
2 hours ago
Hi Sondors eBike Backers!
Just a quick note to let you know Storm is back in China overseeing production. While we await images from the assembly line, here are a few pics of the polished steel tools (for battery box) inside injection molding machine as well as an actual production finished injection molded part (yellow) battery box piece.
Enjoy!
Go Sondors Team
Am I the only one who's starting to suspect that there's an underlying agenda to all these plastic baloney sandwich box pics? After all, Ivars has made a sort of career out of designing and selling his designs for plastic gewgaws (like Happy Meal toys) in the past. Maybe the real reason he's in China is to promote his baloney box design to Chinese ebike manufacturers, and profit by collecting royalties on each ebike manufactured using his design?
In which case, why even bother building ebikes at a loss, then dealing with customer complaints afterwards, when you can fleece the backers and use their money to develop and sell your baloney box instead of building the ebikes you sold? That would explain all the months of nothing but baloney box pics, and only two prototype ebikes reused for different shots.
