@fooferdoggie,
I use N,02 after a climb just like Steve Martin in Little Shop of Horrors. Mother? "Son be a Dentist."
I've got a couple of inches of fully wrappable steerer tube that I can weave a strip of rubber or strap or something around to bind things up a little?
I got my deflopilator finished.
I haven't test riden it yet, but I'm hoping to be able to get my groceries and ride no-hands now like I'm supposed to be doing. 😁
There's no flop at all in the garage.
The handlebars are pretty tight.
I might need to add power steering to compensate? 😁
I wan this puppy makes it easy to put tires on and take them off. only 300.00
I wan this puppy makes it easy to put tires on and take them off. only 300.00 View attachment 214608
Ain't cheap, but worth it if you're dealing with multiple tires/year
I wonder if it would work installing tires with Tannus Armor inserts.
If that tool only worked on small tires, as small as 9", we would get one. We do a ton of scooter flats.
States 24" - 29" but looking at how it works it's not obvious why it wouldn't work with smaller tires.
Probably help some but it's still a hand tool and you'll still need to provide your own muscle.
They don't show/mention a tube being installed in the video... so tubeless only?
They don't show a tube being installed in the video... so tubeless only?
I was always afraid of busting the wire bead while installing Tannus by applying too much force. I think this product would allow you to apply enough force to do it.
I have refused all scooters for two years. They are made by marketing departments and not by people who work in things. For example you cannot adjust the inside brake pad because the motor is in the way. To try to get a solid tire on you have to microwave it in water and will be covered is sweat. It is such a pain.
