subaru_tech
- USA
- City
- chicagoland
Has anyone here pur a half twist throttle on the rockstar.?
Depending on how you are using the throttle.in my case I need that thumb to grip the bar.i raced motor cycles ,and i am use to twist throttle .I think that the thumb throttle works better than a twist throttle ever could.
fantastic how far you went on that battery percentage and grade changes.35 mile ride today, did a huge loop, 67% battery used. Climbed from the river valley in town to the top of coal mine hill, 1500’ elevation gain. The bike just doesn’t stop
So that's a no...I think that the thumb throttle works better than a twist throttle ever could.
You still have 4 fingers to hold on to the bar and you will never have a sore wrist.
Thanks for the info. I did find that bafang has a half twist right hand throttle available. Being new to this bike I find that the thumb control is not linear. It's more on and off.reading some other forums people are saying the twist has a larger potentiometer making it more linear.I have both. For a sporadic use, I prefer the thumb throttle, leaving my grips clear. On one of my bikes I use the throttle all the time, not the PAS, like a motorcycle, I use a complete twist throttle on the right grip. If you choose a twist throttle, be aware that they are generally left-handed, and that your brakes are reversed....you won't get exactly the motorcycle feeling.
I never tthought about a mobility issue with the thumb throttle. I know that it could be easily relocated onto the other side of the handlebars if that made it easier to use.
It’s a suntour sr fork. I don’t think the axle is 162mm..check the suntour axlesOnto the front axle.
my lever pivot broke today and searching the web for a 15mm x 162mm axle turns up nothing.
Has anyone found a replacement front axle?
I think it’s 15 x 110mm,Onto the front axle.
M600 is 120nm of torque..the m620 isn’t 95nm lol@BafangBoy The existing Rockstar controller is 750W at 95nm. Have you considered changing to the 1000W at 160nm version?
