protecting battery connector points - silicone grease or something else?
tomkoszel
Hello,
I've been using my halfords carrera crossroad-e for a couple of months. during the quite wet late june/early july period i cycled through some rain and left my bike locked outside my workplace during relatively heavy rain. on returning home and removing the battery i've found the base of it where it connects with the bike is standing in water that has pooled at the based of the "holder" the battery sits in.
a) can anyone recommend a decent universal-type waterproof battery cover that can be wrapped over my bike's battery when it is likely to be parked outside in the rain for hours? the few i've seen don't seem to be as light as i'd like
b) i've read about silicone grease (and another type who's name i can't recall) and how smearing this over the battery/bike connector points can prevent some of the rusting-type damage the water will eventually cause. would this be a good step to take here or is there a better solution?
thank you in advance for all your help! Tom
dielectric grease remains an antique in electronics protection. FAR FAR superior, modern products originally designed for Milspec and avionics, ACF50 and Boeshield are preferred products, giving far more protection and less mess than grandpa's dielectric.
USE ON ALL CONTACTS and any PCB.
"ACF-50 is a state-of-the-art compound for controlling corrosion on aircraft electrical and avionics systems and airframes. ACF-50 is designed for owners of strut equipped Piper aircraft to comply with new Piper bulletin 5280C requiring lift strut inspection.
ACF-50 kills the corrosion process with just one application and will last for 24 months. Microswitches, cannon plugs, and relays will remain corrosion free. Plus, ACF-50 will easily free seized nuts, screws and bolts. ACF-50 is qualified under Mil-C-81309E, and manufactured under ISO 9000 Certified Processes. ACF-50 holds written OEM approvals from: Gulfstream, Bombardier, ATR Regional Transport, Douglas/Boeing Helicopter, Bell/Textron, Robinson, Enstrom, Sikorsky, MD Helicopters, Schweitzer, Hiller, British Aerospace, Concorde Battery, Raytheon, Piper, Cessna, Pilatus, Beech, Van's, Extra, Air Tractor, Lake, Rolls-Royce, Britten-Norman, Learjet, McDonnell Douglas, and Canadair. Try ACF-50. You will truly be amazed at the results!"
One is a synthetic dielectric grease, Nyogel. The others are specific to electronics and avionic protection. Something Nyogel isn't designed for. "Grease" is not needed!
I use Napa dielectric silicon compound. This completed the connection when I had a faulty battery plug. The bike would not go without it. Plug has since been replaced.
