OverflySportsmanXY
I’m having a problem accessing the pedal assist sensor (PAS) connector on my Overfly Sportsman Electric bike. It’s a rear-motor driven bike with a controller box inside the downtube.
Somehow the PAS was damaged and in trying to repair it I inadvertently unplugged the waterproof connector. Problem is that the controller box appears to be imbedded in the downtube. I’ve tried to view inside the downtube to get a visual on exactly where the other end of the connector is located but to no avail. It seems that the controller box is located within the downtube of the frame but it is not accessible from the outside of the frame. I tried minimal exploration through the battery case on the downtube but it looks like it’s embedded.
I was wondering if anyone might have any information on how to access the controller box on the bike because the PAS sensor cable disconnected and I need to re-connect it with a new sensor.
Do you know if the location where the battery connects to the frame near the bottom bracket is where the waterproof PAS connector is located?
Any help through advice or schematic of the bike’s internal downtube controller placement would be greatly appreciated. Thanks!
