Thanks. I'm trying to avoid a rack if possible - I wear a camelback for my gear, but don't want the added weight of a u-lock inside that, as sometimes I'll have an oxygen C-tank in there if I'm riding above 7500-8000 feet elevation (one working lung, so without eBike I needed the tank for every ride around here).
I LOVE THE POWEFLY 7 - MINI REVIEW:
It's quite well built, with nice welds and workmanship - everything is perfect except the following. I was surprised that the rear axel is not a 15mm thru axel like the front, but is a 9mm mountain bike quick release with slots instead (didn't know if this was typical). The seat padding is nonexistent, but if you get your butt back far enough it's livable, although I replaced it with a slim foam seat that's a little thicker. They also didn't run the derailleur cable inside the frame like with their other eBikes, so it runs along the right side of the lower frame while the rear brake line still runs along the left side. Lastly, I was surprised that the Deore XT shift lever doesn't display which gear I'm in for reference, while the feature is on the other 3 bikes.
It FITS me much better than the 50mm XM700+ that they originally ordered for me, or the 18" Neko+ and 17.5" Dual Sport+ that they had in stock. They did put a 17 degree riser on the handlebar stem (I think a 17x90), after having seen the issues I had on the other 3 bikes. With the riser the riding position is perfect - I've been able to ride down the 1140 foot hill from my house to the shopping center and back up to my home twice (6 mile trip each time), and my hands never went to sleep like with the Dual Sport+ and Neko+. I can lift the front wheel about 1" off the ground when straddling the bar, and I can just get my toes on both feet down to the ground when sitting on the seat.
VS the DUAL SPORT+: Despite the higher weight I still can hop up curbs fairly easily, and the fatter tires absorb the bumps better. At high speeds downhill on the road the PF7 is more stable and not as scary as the Dual Sport+ which put too much weight on my hands and seemed absolutely twitchy. I also have more confidence in the PF7's larger brakes and it's fatter tires which have a tight enough knobby pattern to work well on pavement and dirt. With the PF7 I could lean the bike farther in turns with more confidence, due to the larger contact patch.
BATTERY RANGE: My only concern is that the battery clearly isn't going to last as long as the Dual Sport+. After the ride on hilly roads yesterday and then giving it a full charge, it was estimating the battery will give me 16-48 miles on my next ride (in high vs low power). That's vs 30-55 miles estimated by the Dual Sport+ after the same ride and re-charging procedure. This includes my going to ECO or OFF whenever the ride is flat but requires pedaling, or downhill without pedaling. Before my riding it hard yesterday, the PF7 was estimating 29-94 miles, after only 1/4 mile of an easy flat-ground test ride by the shop after they assembled it.
After a quick 4 mile ride today (with only a 600 foot climb) and before I put it back on the charger, the PF7 estimated that I still had 13-42 miles of battery left to keep riding (13 miles in TURBO, 16 miles in SPORT, 21 in TOUR, and 42 in ECO mode). I would have been able to complete todays ride in only ECO and TOUR mode in the low gears, but I really needed SPORT and TURBO to finish it with decent double digit speed.
So, with a mix of all 4 power levels I believe that I could go an additional 18-21 miles on this hilly terrain; however, I'd prefer to have 30 to last a weekend before charging. But the 32 mile round-trip ride that we have planned this summer is fairly flat with only a slight climb of 300-400 feet over the first 16 miles, and slightly downhill on the way back, with two short hills both directions. So I should be able to make that particular 30+ mile trip just fine.
POWER: I'm not convinced that TURBO (300%) feels stronger than SPORT (200%) when I'm pulling a hill while seated in higher gears with a slower cadence. However, in the lower gears with a higher cadence I can really feel the increase in power on the hills. Unfortunately I poop out with a cadence rate about 65+, and tend to cruise at 50-60 rpm in higher gears, so I wont get as much benefit from TURBO except on a really hard steep hill at low speeds.
