Hi, everyone- I just purchased my first e-bike a few weeks ago, a RadRover. I thought I was doing the smart thing, having it delivered straight to my LBS for assembly and a hydraulic brake upgrade before I even tried it out, but that hasn't worked out so well for me. This LBS is very good with 'normal' bicycles, but has zero prior experience with e-bikes. In spite of that, I remembered how happy I was with their service on my Cannondale years ago (after another LBS left me thoroughly unimpressed, twice) and there are no e-bike shops in my area, so I went and begged them to put my new RadRover together for me.
They got the bike put together and working well in straight-from-the-box configuration, before installing the 203mm front rotor and Luna Cycle "BBSXX-BRKS-M615 Shimano Deore M615 Hydraulic Brake Set with Bafang Ebrake cut off" (which I no longer see listed for sale on their website) that I wanted. During installation, the LBS noted that the Ebrake cutoff would not mate up to my RadRover wiring (even though the RR does have a Bafang controller). The RadRover wiring has two-pronged red connectors, and the Luna brakes have three-pronged yellow connectors. Does anyone know where I can get adapters, or connectors, and/or how I need to wire things up to compensate for this?
Initially, I assumed this simply meant that until I could find and install the proper connectors, I would not have instant motor cutoff when the brakes were applied- the same as if I had 'normal' brakes, with no cutoff... That didn't seem so bad, given that I had bumped up the front rotor size and gone hydraulic, so as soon as I got my RR home I eagerly jumped on it and went for a spin around my neighborhood... which turned out to be a *VERY SLOW* spin, with no motor assistance in any Pedal Assist mode nor while twisting the throttle.
I then reasoned that the open ebrake circuit was activating the motor cutoff, and that, as a temporary workaround, I should be able to hang my old (no longer installed) brakes on my handlebars, and plug in their sensor wiring, thereby closing the sensor circuit and allowing the motor to run.
Nope. No self-propulsion whatsoever.
Can anybody help me understand and correct this problem? I have fully charged the battery. I have properly turned on both the battery and the display. I have properly reinstalled the battery after charging. Am I overlooking something here, or would y'all be inclined to agree that the ebrake motor cutoff is likely the only issue- in which case, why didn't my field expedient fix work? What do I do for a permanent fix? Where do I find any necessary parts? Who would you turn to for technical support here- Rad Power? Luna? Bafang?
Thanks, in advance, to any and all who might be able to help me out here!
GG.
GG.
