I have a 2020 RagWagon (w/ the larger wheels).
For background: The bike has 3,000mi on her. I'm a pretty good mechanic and keep my bikes in good shape. It's never been wrecked and has generally been dry and kept in a climate controlled, covered environment.
A number of months ago I rode to see Bruce Springsteen. On the way back the bike started dropping power. (apparently, baby, I wasn't born to run). Everything works as normal, but as the power kicks in, the power seems to ramp up to the expected level and then drops completely. I can even see on the display where the wattage runs up to a few hundred watts then drops to zero. This happens at all PAS levels and is identical when using or not using the throttle. I can get power back by turning the unit off/on. Pedaling backwards seems to work sometimes, as well as just waiting for a bit (20-30secs?), sometimes. However, any power recovery just sees the issue repeating itself right away.
I'll keep this post strictly to solving the mechanical problems, rather than complain about recent RAD parts and service. I just really want to get this fixed and I'm all out of options, and like Air Supply said, I'm all out of love.
Here's what I have done (in the order I recall):
At this point it seems like I've replaced everything but the LCD head unit, which would seem to me to just be a 'dumb' display rather than controlling anything?
I live in Austin TX, and there are no longer dealers on service centers locally.
Anyone have advice? I really do love this bike and want to get it running correctly again. I was able to return the wheel/motor assembly to RAD, but other than that...I've paid to replace damn near the whole damn bike and it still isn't running.
Help me Obi-Wan...you're my only hope.
- General maintenance and inspecting connections and wires (issue repeats)
- Inspect crank (issue repeats)
- Unplug and isolate brake sensor cables (issue repeats)
- Replaced fuses in battery (issue repeats)
- Borrowed a RAD battery from a friend to test the battery itself (issue repeats)
- Ordered and installed a new controller from RAD (issue repeats)
- Ordered and installed a full rear wheel assembly from RAD (issue repeats)
- Ordered and installed a battery tray from RAD (issue repeats)
- Ordered and installed new wiring harness from RAD (issue repeats)
