@Voltman
Thanks for the update. Just some more suggestions:
1) More than just 1 set of bottle holder bosses (if room permits). We use these for more than just bottles (eg. pumps, locks, etc.) Possible locations: (1) Seat Tube (2) Underside of down tube (3) Head Tube left & right (similar to the Radrover).
2) Discontinue the compass/bell combo. The compass never worked because it gets stuck from the sloped handlebar. These types of compass need to be level in order to float freely in the liquid. The compass makes the bell unnecessarily big. Wish: Upgrade to the integrated brake lever bell (like the Radrover), or just a smaller bell without the compass.
3) Personally, I am okay with a *black* suspension fork with the white Yukon. This may save you cost and logistics if you don't have to stock both black and white forks.
4) Rear derailleur guard to protect the hub motor power cable.
5) A bigger battery option: I noticed you are using the new 440mm (~17") "Reention" integrated battery standard (
(Link Removed - No Longer Exists)). I hope I'll be able to upgrade my battery from Voltbike directly when my stock battery needs replacement.
Juiced Bikes also uses the same battery and they will have the following *upgradable* batteries:
That's all I can think of for now. Hope this helps!
