New build
Shortened the cable between battery and motor (so only the XT60 connectors are used) and tidied up the cable clutter. Nice and neat.
On my install...
1. I sealed mine off with heat shrink and tucked in in the wire Loom along with the other cables. I did not cut them.
2. A water tight Butt Splice that I then put heat shrink over each wire. If you stagger them you can make a tighter bundle.
3. Spacers are typically inexpensive.. But more importantly is maintaining a good chainline to the rear cassette. You should be straight front to back when in the middle of the rear cluster .
Wouldn't duct tape be the "I'm on a budget" solution? 😄
