NCM DeHawk/Reention Battery Specs
FullyCharged
Yesterday I started researching into the batteries for our NCM bikes. NCM has them listed as DeHawk which is using the Chinese made Reention Dorado+ Series battery cases.
Here's some data I've collected recently while searching for a 48V 21Ah 505mm compatible battery for my Moscow Plus. I will update this thread as I find more info.
Manufacturer's Website:
Dorado+ 48V Specs:
Battery Info:
NCM uses the 505mm sizing on their bikes. Another member on EBR told me he made molds to fill the void for the smaller compatible battery size (440mm).
Good to know if you get stuck with the wrong size battery.
Teardown/Part List:
PDF LINK for use with google translate.
Other Compatible 48V Batteries:
This Max version is slightly taller to accommodate 15 more cells than the Dorado Plus (Stock)
36V Compatible Batteries:
Hello hope you are well I have the 625wh battery would a 21amp be usable on it would the controller handle it ? Do you know ime not too savvy with electrics ....
Agreed. If you are looking for a replacement battery then @Jenny Mao and Aijiu are your best bet for a great battery (Samsung cells inside) for a great price. She sells 14ah up to the 25ah I purchased. See my review of the battery from Jenny here.
