Most lightweight and portable 48v charger?
geekeasy
It sure would be nice to be able to throw a charger into saddle bags or a backpack and be able to charge my bike at my destinations.
I can do that with the charger which came with my bike (Lectric lite), but it is pretty big and bulky.
Does anyone make any 120v chargers which are a lot more portable?
The ones on ebay weigh about a pound. Look for max 54.6 v on the label.
Connector often does not match what is on your bike. Buy connectors at newark or digikey. Pick up soldering iron and rosin core solder at the same time. Also perhaps some heat shrink tubing. I shrink it around the connections with a hair dryer.
My 2A Lectric charger is the heaviest, and runs the coolest, of four chargers I have. It weighs 650g including a 3' cord.
This 3A charger has a noisy fan, but is the lightest of the four, at 450g.
If you buy from Aliexpress... You usually have a wide selection of input and output connectors/plugs.
Plus it's typically the same exact charger and it's less expensive.
