Ann M.
If regenerative braking is one of your desires, rudym, you need to purchase a direct drive hub motor system. Golden Motor & Crystalyte (the Crown model) both make non-geared hub motor systems that are reliable, offer regen and have plenty of torque. With the Golden Motor Magic Pie systems the controller is integrated into the hub motor with cooling fins on the outside of the motor to help disperse heat. This makes it a little more simple to install since you won't have to wire in the controller. With the Crystalyte hub system, you do get choices for your controller which can be advantageous but requires a little more work for you.
Mid drive motors are all geared units so you can't do regen but the weight balance is nice and it's easier to fix a flat. I know many people grump here about fixing flats on hub motors; however, if you choose a better quality tire, like one of the Schwalbes that have superior tread mix and add a tire liner, then you are less likely to experience flats unless you ignore the tire pressure and end up with a pinch flat. Given that the hub motor adds a bit of weight to the wheel, a few extra ounces of protection won't make a major difference on performance or handling, particularly since you mention that most of your riding is going to be on streets.
If you want to go the DIY route, do your homework and watch videos by different people to avoid some of the difficulties during installation. And remember, there are competent ebike techs who could do the install for a modest fee or aid you. It's a good idea to make friends with a local shop or independent mechanic who specializes in ebikes
