D
Deleted member 46571
Guest
Hi allBullshit.
It is not the torque that drives the e-bike. It is the power of the motor. Especially the mechanical peak power.
Take an 80 Nm mid-drive motor on an e-MTB with gearing ratio of 0.75 (granny gear). On climbing, such a motor will produce as much as 120 Nm of torque on the rear wheel. A hub-drive motor would need to have 120 Nm of torque, and it will probably fry on a long ascent.
Are the whole torque
Conversation
torque , motor power (watts) and rotational speed are all linked
And part of an equation
Yes a motor spins and pushes or powers the bike how well it’s does that and how quickly it is applied is torque in nM
The torque and speed relationship is inversely proportional since the rated output power of a motor is a fixed value. As output speed increases, the available output torque decreases proportionately. As the output torque increases, the output speed decreases proportionately.
So torque is akin to acceleration
So the x35 as far as I understand had the nylon reducing drive cogs from the motor to the back wheel hub this caused drag
i believe that x20 is more direct drive so much less drag and it is noticeable
Placing a motor directly on the back wheel and direct driving it is the most and best way for efficiency
Mid drive goes though chain ring , chain, derailleur and cassette
This produces losses
But the bigger picture for me is
Not comparing hub to mid drive torque (apples and oranges)
Is comparing x35 to x20
Apples to apples
Here the thing and to some of the points made by others
I now have a lighter bike, lighter motor with less wheel drag and apparently more torque
Do I notice the difference
Yes but it’s no where near what I expected it is subtle
but I believe it’s because of the weight difference of the bike
not because I have more torque
The scott is quicker on the flat when motor is off at 15 mph it should be with no drag and a lighter bike
But not quicker up the hills it should be
as slower speed more torque if the figures are what they tell us
