D
Deleted member 46571
Guest
Hi all
so Wanted to pass on my obeservation and experiance on 3 bike and x35 and x20 motors
and welcome some feedback
Orbea D50 x35 medium frame, 16kg, marthon + tyres (not light but no puntures at all), did 5200 miles in a year no issues, then Orbea m20 small frame 13.5 kg 7200 miles again M+ tyres no punctures, no issues, never had a motor issue or app issue, with either, did around 25 miles a day about 345 days a year all weathers, brilliant system a joy to ride
just got scott addict e-ride 20 12.3 kg with mudgards lights Swab pro ones, ride 4 times now on 125 miles
so there is the premise
preformance from D50 to M20, what a difference basically down to the weight saving different ride much quicker on the flat
so the scott medium frame, lighter bike a big difference from M20 NO
scott is a different bike different gearing, bigger frame, lighter tyres, if i took the M+ and the slime inner tubes off the M20 i would loose 1 to 1.5 kg
so comparable weight against the scott, also the x35 motor has a lot of drag they say it transparent its not the reduction gogs give it about 1 kg drag
what noticable with the x20 motor is there is a lot less drag, nice, is it drag less not sure but a big difference
so to the question
is the x20 motor more powerfull have more pull than the x35, MAHlE say its 55nm, but comapre it to a mid drive motor and quote loses across the drive train for mid drive motors that true but , smoke and mirrors
why not give values x35 vs x20 i have seen infomation on the web that x20 torque is less than x35, 23nm X20 vs 40nm x35, so where is the truth
well x20 is lighter by 200 - 300 grams and has less drag so with more torque there should be significantly have more pulling power and my scott is lighter
but because my orbea has M+ tyres on it difficult to asses one against another, my view is that there is not much difference and thats strange as
i have a lighter bike, mainly due to tyre difference lighter motor and battery i have SRAM rival digital gears which is heavier than M20 ulterga mech i think
Scott does feel a bit quicker, as it should, but its early days yet still assesing, but its marginal, but the scott is a nice ride
i complete the same route with 8 big hills to try to comapare one on one systems
as a electronic and mechanical engineer i know how this system works, to produce a smaller motor with more torque is difficult, but possible
but i am suspicious when a munfacture does not comapre its own motors against each other, but defelect and compare to a mid drive instead
so in conclusion preformance wise is the x20 better than the x35 note (on D50 and M20) it was the x35 version, not the x35+which is better agian
jury is still out it is noticable, i was expecting a big difference, but its not, also the peddle torque and AI is it required, NO, i had no complaint with the x35 worked perfectly for me
i will let you all know after a couple of months my thoughts on the Scott and x20 motor
one thing more the apps "ebike motion" and "mybike" worked perfectly for me on x35, on the x20 its a nightmare, MAHLE relaeasing an unfinished product to early
so to the question
