Luna charger - 80% max charge?
tlippy
If you charge your 52v battery to 80%, that's 41.6 which is below the controller's cutoff voltage. Doesn't make sense.
I use a Luna for my CCX and usually charge at 80%. That comes in around at 55.8-56. (per log) I do note a small differential between on board and luna readings, and get slight variations between charges using the 80% charge setting.
You don't calculate 100% between 52v and 0v
It's calculated between the Full Charge Voltage and Low Voltage Cutoff .. so depending on your specifics approximately between 58v and 45v
v
