tomjasz
- USA
- City
- Minnesnowta
Specifications: BBSHD
Material: CNC 7075 T6 Alloy
Finish: Anodised Black, Red
Size: 36T, 42T, 46T, 52T
Offset: 28T/36T 5.2mm, 42T/46T 18.3mm, 52T 16.3mm
Weight 28T 68gm, 36T 105gm, 42T 210gm, 46T 228gm, 52T 238gm
Tooth profile: Narrow/Wide
Compatibility 1-11 speed (most chains), Sram 12 speed
Motor BBSHD
Specifications: BBS02
Size: 28T,36T, 42T, 46T, 52T
Offset: 28T/36T .8mm, 42T/46T 9mm, 52T 6.5mm
Weight: 28T 58 gm, 36T 85 gm, 42T 147gm, 46T 166gm, 52T 210gm
Make sure you check the User/install Guide before install Bling Ring user guide V2
PLEASE NOTE: This is for BBS02 motors! It will not fit
