Think this has been posted before but JIC -
What the settings control -
P01: 1-3 Backlight Brightness Adjustment, 1 Lowest, 3 Brightest.
P02: 1 Mileage Unit Setting. 0: km, 1:mile
P03: 48V Voltage Selection Setting. 24V 36V 48V
P04: 10 Sleep Time. 0: No Sleep, Other Numbers Are Sleep Time, 1-60 Minutes
P05: 1 Power Gear Adjustment,
P06: 20 Rim Diameter. Mine needed to be set to 25.5 to correct my odometer
P07: 1 Number of Speed Magnets. Range: 1-100
P08: 32 or 45 Speed Limit: 0-100km/h
P09: 0 Throttle toggle. 0 = active, 1 = inactive
P10: 2 Drive mode.0: Pedal Assist only, 1: Throttle only, 2: Both pedal assist and throttle.
P11: 3 1-24 PAS sensitivity. Higher numbers take more rotation to turn on
P12: 3 0-5 PAS strength. Higher numbers cause motor to come on stronger
P13: 12 Magnet type 5, 8, 12
P14: 18 Current limiting. 1-20 amps
P15: 39 I think this is the voltage where the motor cuts off.
P16: 0 Odometer zero. Long press the upper key
P17: 0
P18: 100%
Here's the factory defaults:
P01: 1-3 Screen brightness
P02: 1
P03: 48V Voltage
P04: 10
P05: 1
P06: 20 inch tire height
P07: 1
P08: 32 - 45 max speed
P09: 0
P10: 2
P11: 3 Pedal assist sensitivity
P12: 3
P13: 12
P14: 18
P15: 41.5V
P16: 0 mile odometer
P17: 0
P18: 100%
P19: 0
P20: 0
