Hi guys! Küat sent me their NV 2.0 hitch rack a couple of years back to test and use during my ebike review adventures and it has worked very well. The rack is strong, comes in 2" or 1.24" hitch configurations, supports two or four bikes, folds up, is aerodynamic, and safer to use than a roof rack because you won't accidentally wreck your car in a low garage or drive-thru restaurant I did a full review of this rack here. I love that it fits a wide range of tire types from road bikes to plus sized mountain bikes and even fat tire bikes. Hitch racks are great for heavier electric bicycles because they provide more support than hang style racks... though they are expensive.
The thing about the 2.0 NV hitch rack from Küat (and most other hitch racks) has been that you still need to lift the bike up in order to load it onto the rack. Thule has introduced a folding rack called the Easy Fold that includes a ramp by default and now Küat has an optional $89 rack that's super easy to install and use. In this video, Marc and I unbox the NV 2.0 Access Bike Ramp and then install and test it in this video:
Pros:
- Easy to install
- Doesn't take much space, slides to be compact
- The guys at Küat emailed me and said "Dipping those ends is a great idea! Also, we do have brackets for the original NV, so the ramp is backward compatible. Glad the rack is treating you well." which is awesome! Backwards compatibility
Cons:
- Stores separately from the bike rack
- Made from steel that could rust if the powder coating paint is scratched off
- More expensive than I expected
Other:
- Weight: 5.8lbs (2.63kg)
- Material: Steel (powder coated)
- Dimensions: 34.5" x 4.25" x 4.25" (87.6cm x 10.8cm x 10.8cm)
- Expanded Length: 55.5" (141cm)
As always, I appreciate your input about what bike racks and rams are working well, what you think could be improved about the Küat solution, and anything else
Pros:
- Easy to install
Cons:
Other:
