Wow that is unfortunate, I ordered mine directly from Leon Cycle (Moscow Plus 29) in Richmond. It was shipped immediately and I put it together in a hour or so. I am in Ontario (Southern) also.
I am a complete novice when it comes to bikes and biking, but I'm quite mechanical and electronically inclined. The only issue I've had so far is the front fork would not move, no matter what I tried. Turned out the two hex bolts on the locking side, were not set correctly. Watched an online video and corrected the problem.
To me and it's only a guess, I would take a look at where the battery connects to the socket on the bike make sure the terminals on both connections are clean and not loose. Then start tracing the voltage to the controller and out of the controller. Does the bike simply shut down or does the power remain on and the electronics start acting strange. The dealer should be able to measure the controller output current and voltage to the motor. They should also be able to test the battery under load conditions, by connecting a wheel (any powered wheel should work). I'd hoist the bike up, turn it on, and then start moving components around (like the battery) and seeing if a loose connection is causing the issue. Either a mechanical battery connection or a soldered internal connection could have come loose in shipping.
Good luck.
Good luck.
