Dave-this may be a good question for Frey. I know with my Lectric XP, the switch to an 11-34 chainring will result in better pedal response and probably allow me to go faster. In fact, I just purchased it for my son for Xmas...I have just been out on my bike (Frey EX) and on the flat, my legs are spinning very fast in Sport PAS 5 and top gear and I am going around 22mph.
The question is - would a bigger drive ring get me more MPH and if so would this be damaging to the drive train?
Cheers
Great. Anybody have a good link for US provider for Race Face to fit Bafang Ultra.just ordered one, happy days
Race Face Narrow Wide MTB Single Chainring | Chain Reaction
Buy your Race Face Narrow Wide MTB Single Chainring from our Chainrings range at CRC. £18.99. Free delivery available.www.chainreactioncycles.com
confused with that? that will only take a 30t or 32t chainring which will mean you will be spinning your legs very quickly and going not very fast.
Race Face CX Narrow Wide Chainring | Jenson USAGreat. Anybody have a good link for US provider for Race Face to fit Bafang Ultra.![]()
the ultra has a 5 bolt pattern and the pitch of the bolts holes are 130, if you do buy a chainring make sure it has these dimensions, also the standard ultra chainring has 40 teeth, if you buy one with fewer teeth then your top speed will lower, more teeth and your top speed (when peddling) will be higher. there will need to be a happy medium with this so i think 44 teeth would be the maximum i would go on that.I like the idea of being able to change out the chainring. But I'm intimidated by just how you go about getting the correct ring for a particular bike. That is ... bolt pattern, spyder, keeping the chain line the same. yada yada yada. Any help is much appreciated.
Yes, I’ve sold a few and ran RaceFace, Lekkie, Luna, and a China copy. All narrow wide and wouldn’t run Connex eBike chains. Luckily all of my builds had good chainlines. I’m wanting an ultra bike but it’s still the Wild West, like the early years of the BBSxx series. Bad, to worse parts supply chain.RaceFace are from the USA check them links out above
I've experimented with the BBS02B and the stock bbs02b chainrings starting with a 46t which seems to be a happy medium. Then I tried a 48t for more speed over the summer which I found made me and the battery a bit more tired. I didn't notice the motor heating up, but I do ride to exercise and try to do most of the work when I can. I was able to reach 30+mph with a 11- 28t in the rear which probably isn't a good idea on my ol' bike but it was fun experimentingYes, I’ve sold a few and ran RaceFace, Lekkie, Luna, and a China copy. All narrow wide and wouldn’t run Connex eBike chains. Luckily all of my builds had good chainlines. I’m wanting an ultra bike but it’s still the Wild West, like the early years of the BBSxx series. Bad, to worse parts supply chain.
Thanks for the sizing explanation.
Forget about the motor at 52t...my skinny legs will be burning up.I run all OEM these days. They will run Connex eBike chains (132L)
I have run them all. I think Lekkie rings are a great solution to chain drops. They have decent dishing and the 42T, IMO, with 11x34 is a sweet spot. I added a Grin Shunt and tied in a CA3. The feedback was outstanding. It revealed the motor was burning up watts and stressing when I ran up to 52T chainrings. Only the HD stood up to the hammering.
I’ll send you a 42t to try out and return. Ships cheap first class.Forget about the motor at 52t...my skinny legs will be burning up.
28t in the rear seems to be big enough for me at this point as I have some hills but typically not that steep. I often take them in second @ 24t
I do get some chain gurgle when in 1st and an occasional chain drop if I'm riding bumps like roots.
Is the offset on the Lekkie the same as the stock Bafang rings? Or closer/further from the motor?
I might just take you up on that.I’ll send you a 42t to try out and return. Ships cheap first class.
