JimViktoriia
- USA
The Jetson Haze has a bolt lock that can be pushed into the space between ther rear disc brake elements. The locking does not require the use of a key, while unlocking does require a key. This feature has the potential to lock the bike in circumstances that can lead to accidental damage (to the disc brake) and an inability to move the bike in a remote location (assuming the key is not available). Several simple solutions are available to Jetson Haze owners. One solution is to fabriacate a small plastic clip that works like a clothespin between the frame and the flange on the outside of the lock bolt. Another simple solution is to tightly wrap a single "Gear Tie" (costs about $1.20 each and sold in packs) twice around the locking bolt (between the frame and the bolt flange). The second solution allows you to place the rubber cover over the lock (if you twist the Gear Tie once or twice and bend it toward the frame). These solutions work well and the second one is accessible to almost anyone.
