Dragnlady i am doubting the 2019 controllers would be programmable but may be programmed different and slower in level 1
Maybe AHICKS is right and there is a way to change mechanical things on the bike and fix this
200 watts all the time seems like a lot to me AHICKS....
Dragnlady i feel for you, i have been in exactly the same boat and was not happy either
That raliegh bike looks cool, i would like to test ride one of those, will see if they have any in phoenix
Keep us up to date on what rad power says
It's not 200 watts all the time. It's 200 watts maximum.
In PAS 1, you're limited to 200 watts maximum (or something just under that, don't crucify me if its 179 or something).
For instance, when pedaling slowly on a level hard surface with little effort applied, you may only be drawing 100 watts at 4-5-6mph. The motor has power on it because you are pedaling, but it certainly has very little load on it at the lower extreme seen in PAS1. If more effort is put into it and speed increases the wattage also increases - but is limited to 200 watts. If you want/need more power, you'll need to switch to a higher PAS level.
The issue with this RAD City (and most other model Rads) is that it's top speed is easily reached with very little effort. It's not going to go much faster set at PAS 5 than it is in PAS 1 because it's top speed is being limited by your cadence/how fast you can peddle. You can't peddle fast enough to go any faster. You are in effect "ghost" pedaling at just 15mph, and this can be achieved under the right conditions even set at PAS1. THAT'S the issue here.....
Imagine a bike that is geared similarly to your bike when your bike is in 4th gear. This imaginary bike's max speed is the same speed you are capable of in 4th - due to the gears it's using. A bike might be set up like this for mountain riding for instance. How would we change that if we were going to convert it to more of a road bike? Simple, we would change to a different gear set. This new gear set would be much more difficult to top out from a cadence perspective. Now, our top speed will be determined by our ability to pedal hard enough to go faster - not our ability to pedal any faster. Now we can easily stay up with the pedals - no longer stuck in hamster wheel effect.....
This re gearing is what I'm suggesting the OP have done to her bike. She will then have joined the many others that have done the same thing to their late model RAD bikes - myself included. It will then be easy to stay up with the pedals in 7th gear, and getting exercise while pedaling in 7th will be assured - guaranteed......
Go back and check out the links in my first post on this topic. You'll see comments from many others that have run into this issue, and how they cured it. It's NOT just my opinion, and those are not the only posts related to this issue from owners of the RAD bikes. -Al
