Tronic Jon
Throttle does not work when the killassist switch closes across the brake inhibitor wire pair (as you already suspected).
The future solution you have already suggested: that Juiced make a "0" setting in the power level menu. That would be quick and easy to use.
Till then, I am enjoying my killassist switch. It lets me go back and forth from manual to assist very quickly.
You could glue it just about anywhere, even on or near your throttle.
PS: it was the first mod I made to my bike. I despised the always-on assist and that I could not go on a night ride using just the headlight. God, that all sucked so bad and I have forgotten how unsatisfactory it was. I am constantly riding the bike going OFF and ON with the assist. The switch is used very frequently; as well, the on/off throttle button. I do not have a throttle anymore.
@Reid
Can you kindly post more close up photos on exactly what wire and where you tapped into to tie into the actual switch?
