Unfortunately ya gotta add fluid down at the caliper and push everything up to the lever to bleed the air out with a syringe. First make sure your pads aren't stuck partially extended or you won't get al the fluid in there you need. Then make sure all openings are tight and your good. Takes 15 minutes to bleed both my front and rear.
