That is an interesting add on....
Below a thread where Pushkar discusses differences
Quick update on Archon / Rohloff / Kindernay tests | Electric Bike Forums - Q&A, Help, Reviews and Maintenance (electricbikereview.com)
A few thoughts on the difference between both
Shifter:
- The Rohloff has a twist shifter (right or left) vs a dual (side) push shifter on the Kindernay that can switch one or three gears at a time. So depending on comfort and range of accessories one may fit your better (Dropper post, thumb throttle, twist throttle…)
- The twist shifter gives you a visual info on the current gear, I don't think the Kindernay has any indication of the current gear.
- You can quickly switch all gears on a twist shifter, you would have to do up to 5 pushes on the Kindernay
- Pushkar mentioned the hydraulic shifter on the Kindernay allows shifting on higher load than the Rohloff.
- Kindernay said they will have a single side dual push shifter (may be next year…)
- No visibility on an electronic shifter for either of them working with the Bafang. Although if Kindernay does decide to make one, it will most likely work with everything.
Hub itself:
- Range 526% for the Rohloff vs 543% for the Kindernay. Not really a huge deal
- True Through Axle on the Kindernay
- 1400g for Kindernay vs 1700 g for Rohloff (about a pound heavier)
- Cage system on the Kindernay makes it a lot easier to service the hub or swap wheelset
- If ever a Gates belt system is an option, minimum rear sprocket is 22T on Kindernay and 19T on Rohloff (Kindernay does say they are working on more choices...).
So eventually a bit more choices on Rohloff.
Question for Pushkar.
Will you offer either left or right shifter for the Rohloff?
