walkingman57
Happy to say that my HT1000 arrived over the weekend. It was well packed, no damage at all was noted. It took all of 1/2 hour to fully assemble. Super easy in spite of no instructions since it was mostly assembled already. It arrived with about 60% charge on the battery, so I didn't have to wait to give it a spin. I placed the order at the end of August 2021, so all in all it took 7 months of patience to receive. Cecelia was great to work with and was always super responsive to texts through the Alibaba app. High praise is due.
Specs/ordering choices made:
Medium size frame (I'm 5'-8" with 31" inseam)
44t Chainring
Rockshox Yari
Maxis 29 x 2.20" tires (65 psf max)
Shimano M8000 11 spd 11-46 cassette
Lighting
Rear rack
48V standard battery
Magura MT5e brakes
I asked about Lyrik fork, but decided against the extra expense and that I probably wouldn't know the difference in performance, anyway.
My main use will be for commuting, so I'm optimizing it for fast cruising. Will be adding/replacing:
-spd/platform combo pedals
-shock absorbing dropper post
-shorter no-rise or negative rise bars
-fenders (going with Tom D's recommendation)
-bigger chainring, maybe
-road specific tires
-Watt Wagons Archon controller
This is my first mountain bike and suspension. I'm a 63 year old, dyed-in-the-wool weight weenie roadie who's used to 20 lbs bikes, so I was curious about how I would react to climbing into the cockpit of this 75 lbs beast. I've only been able to spend 20 minutes or so on it, but my initial reactions are nothing but smiles. The throttle made me wish I had a seatbelt at first, but now it's just cool to hit on the climbs. I have to say that the sensation of being on a heavy bike literally disappears when PAS or throttle kicks in. What is really different, though, is the sensation of being up high. It's sort of like the difference between dropping into a low slung roadster vs climbing up into a lifted rock hopping truck. I'll take a picture with my roadbike next to the HT. There must be a 3-4 inch height difference. I can't put my foot on the ground while remaining on the saddle, thus the dropper post. Fortunately, the top tube drops at such a steep angle and stand-over height is great. The pedals are a little cheesy and the seat post is too short. They're toss-aways to me, anyway. The saddle's not bad, but I'll probably pull one off of one of my road bikes to keep my backside happy. In those 20 minutes of riding, I mostly used the bottom 4-5 cogs in the cassette. My initial impression is that there is little or no feeling of motor drag with PAS turned off, especially when pedaling in the larger cassette cogs.
I'm used to riding with 100 lbs of pressure in skinny 28's so the 2.2's feel like being on the road with slippers. Just for fun, I pumped the rear up to full 65 and left the front at about 45. Huge difference. I think it's going to take some time to get the confidence to dive into turns like I do with my road bike's slicks, given the high body position on the HT. I'm planning to cut down the bar ends because the super wide hand position makes my wrists ache. I might even go to a negative rise bar to get better body position to cut down on wind drag.
All I can say is "yes", it was worth the wait. Now I'm going to have fun tinkering with it to see if I can iron out the best and most efficient performance out of it as possible. I figured that buying it direct from China really meant that I'd end up being on my own as far as support is concerned, but there are tons of resources online on how to best approach problems and I'm pretty mechanically savvy. I'd love to connect up with other HT owners to share info. I'll post more reactions as I get more time in the saddle and start changing components out.
That's it for now. Cheers folks!
Best regards,
Steve
44t Chainring
Rockshox Yari
Lighting
Rear rack
Magura MT5e brakes
Best regards,
Steve
