According to the web site, the following items have a 7 day warranty
frame, forks, handlebar, seat post, saddle, brakes, lights, crankset, pedals, rims, wheel hub, freewheel, cassette, derailleur, shifter, motor, throttle, controller, wiring harness, LCD display, kickstand, reflectors, and hardware. Warranty within one week after receiving the goods. Parts damaged during use after seven days need to be charged
This Limited Warranty does not cover:
- Ordinary wear and tear not the result of defects in workmanship or materials. Wear and tear can be assessed by Himiway. Parts not typically covered include but are not limited to:
- Brake Pads
- Rotors
- spokes
- Tires/Tubes
- Chains
- Chain Rings
- Cassettes
- Crankset
- Parts compromised due to corrosion due to the elements (moisture, heat, etc).
- Damage or deterioration of the surface finish, appearance, or aesthetics of the product.
- frame, forks, handlebar, seat post, saddle, brakes, lights, crankset, pedals, rims, wheel hub, freewheel, cassette, derailleur, shifter, motor, throttle, controller, wiring harness, LCD display, kickstand, reflectors, and hardware. Warranty within one week after receiving the goods. Parts damaged during use after seven days need to be charged.
