steve mercier
Take a look compact on your glasses.Yeah, not used to a mirror there and keep knocking it out of position. Still, I like this Mirrycle bar-end mirror much better than the EVT helmet mirror I tried.
Very cool design! Might just return the EVT and try this as either a 2nd mirror or one to take on trips that might involve rental bikes, which seldom have mirrors.It took me a long time to convince my wife to get rid of the handlebar mirror and switch to the Take a Look " compact " eyeglass mirror but now she would never go back. The field of vision is exponentially greater and you can easily pan behind you with a slight turn of the head.
My friends and mentors on EBR will be relieved to know that I'm just about done with the hand-wringing over the SL. Only 2 remaining issues:
1. Storage: Want just the right amount without resorting to a big trunk bag. This will take time and a lot of trial and error. A 3L waist pack may be involved.
2. Tubeless tires: The tubeless Pathfinder Pros go on in 2 days. Tubeless tires weren't even a thing the last time I was an avid cyclist, and I have no experience with maintaining or repairing them.
Imagine my surprise when I noticed, 2 days after taking delivery, that my SL has a dork disk!
If that doesn't give the much-maligned dork disk some cred, I don't know what would.
First, thanks for all your help in this venture into the unknown with the SL. Working out fine, as so many of you predicted.how about a custom wedge or half frame bag? way less drag than a burrito bag or other front bag, weight much closer to the center of the bike, etc. what are you trying to store? as many here know i’m quite a minimalist on the bike, over time having done unsupported centuries with a smaller bag than yours. with your phone on the bars, tubeless tires, and a pocket or two in your shorts, what do you really need on the bike
here’s a good article with lots of links to custom
bag makers : https://bikepacking.com/gear/custom-frame-bags/
the only real downside of a medium frame bag (that doesn’t block your bottles) is in heavy crosswinds. i don’t think it’s as windy down there as it can be here, likely not an issue….
seems very inelegant to have three small bags on a lightweight bike used for moderate length rides. i bet everything you’re describing would fit in a larger frame bag. get a side exit bottle cage and no blockage of either boss location. capacity would be around 3x the current one, if necessary. would easily hold keys, credit card, id, backup battery for phone, multitool, snacks, tubeless repair pill, CO2 and inflater or minipump, vest, tube and tire levers if that’s your thing. i don’t carry a tube and in 15,000 tubeless miles on bay area roads have not yet encountered a situation in which it would have helped. putting a tube in a tubeless setup can be a messy pain i absolutely would bring one for a long ride off road out past civilization, bike packing, etc, but for a 50 mile ride in an urban area? nah.First, thanks for all your help in this venture into the unknown with the SL. Working out fine, as so many of you predicted.
Minimal but prepared is my goal, too. Don't plan to carry much on routine rides. Have the Topeak MondoPack saddle bag coming for a few tools and tire repair wherewithal, including the spare tube I've been told to carry for the tubeless Pathfinders about to be mounted.
Might be room left for some small incidentals there as well. The small frame bag will cover the rest of the small stuff. A bigger frame bag would start covering bosses, and I'll need all 3 if an RE comes into my life.
The only remaining item is a light high-vis mesh vest or long-sleeved solid shell. Since it's often hard to predict which I'll need, I often end up wearing one and carrying the other.
For that, I'd like something more convenient and elegant than a stuff sack strapped to the rack (above). Thinking a small, low-profile rack bag — which nobody seems to sell at the moment. That's where your helpful list of custom bag makers might come in.
Jeremy, let us be honest: In the case your tyre would be as damaged as the inner tube needed to be fitted, better give your wife a phone call for the help with the carincluding the spare tube I've been told to carry for the tubeless Pathfinders about to be mounted.
OK, 2 different LBS guys told me to carry a tube for a tubeless puncture that won't seal by adding sealant from a small Stan's bottle. But you guys just talked me out of it — which should leave room for the desired alternate outerwear in the saddle bag.Jeremy, let us be honest: In the case your tyre would be as damaged as the inner tube needed to be fitted, better give your wife a phone call for the help with the carBecause I would not be able to handle the situation myself, so you would be even less qualified to do the replacement
Incidents leading to as a severe cut in a tubeless tyre as removing the valve, tyre, getting soiled with the sealant, and then applying the inner tube are necessary might happen on a technical singletrack involving the rocks but is highly improbable where you (or I) are riding. Save the space, get rid of the inner tubes and use the space for a small tubeless repair kit which you might have never used, either
The whole point about tubeless is you would hardly suffer from any puncture.
Then the rack would be free for unexpected loads — hopefully secured with the small bungee net I just ordered to try, to be stowed now in the saddle bag.
@mschwett , searched high and low for a larger forward frame bag that wouldn't block the TCU and/or top tube and/or down tube bosses. The small one shown is the only ready-made solution found, but a custom bag might work.
Sticking for now with the Any Bottle Cage shown for my thermos. Will look into a tubeless repair pill.
@Stefan Mikes , I foresee a lot of "how to deal with a tubeless flat" YouTubes in my future. Got some tips from one experienced LBS guy, but without practicing at home, I'll probably remember little of it in the field.
What about carrying a plug kit for small holes and a tire boot for gashes?
Will look into Aerotech Designs. My cheap shell has zip-off sleeves, but they're a pain to put back on. And the "vest" I'm left with is solid, not the open mesh I prefer.I always have that spare tube, wrapped up in some electrical tape in case I need some of that. Had to use it one time a year or so ago when I got enough of a gash that I couldn’t fix it with the usual tricks. Never leave home without it. Also keep a foot or so of electrical tape stuck to the bottom of the top tube. Sometimes it’s not you with the problem, but someone you are riding with or come across who can use a hand.
Re the jacket/vest, Aerotech Designs makes a really nice hardshell jacket that I personally usually use as a vest. Good quality stuff. Of course, there are many choices out there!
I've never needed anything in my kit except the battery air pump. And mostly it was used to help others...@DaveMatthews: I have got a Lezyne CO2 Blaster repair kit, similar to yours. Only I have never had to use it
Now, anyone of you who could fix the tubeless with a spare tube: please tell me how you do it, starting from how you remove the tubeless valve, exactly?![]()
I chose tubeless for my Vado SL as my riding buddies say: 'No punctures since I "milked in" my wheels' (a slang term here for going tubeless). I've been to so many group rides when we had to wait for the wretches having their inner tubes punctured...I've never needed anything in my kit except the battery air pump. And mostly it was used to help others...
