Having owned a Tesla for 9 years now, I'm pretty familiar with lithium battery care, and have read my share of articles on the subject. My car still has its original battery, btw.
One aspect that needs to be defined is:
What is a Cycle?
- Some articles appear to define a Cycle as "Any use followed by any charge back to the use start SoC." So, you could start at 80% SoC (State of Charge), ride down to 30% SoC, then charge back to 80% - and that would be 1 Cycle.
- Some articles appear to define a Cycle as "A full Depth of Discharge (DoD) followed by a full charge." With this definition, the above example (80% to 30%) results in only a half-cycle, so you would need two rides 80% to 30% to have used 1 Cycle. Tesla itself uses this definition.
Either way, this leads to the definition of
What is Cycle Life?
Tesla says:
For Li-ion cells, manufacturers define cycle life as the number of full discharge-charge cycles that it takes to reduce a cell's capacity to some fraction of its original state. (A common threshold used in the laptop industry is 80 percent.) Note that the cell is generally not completely dead at the end of these cycles. It has a significant number of useful cycles left, just at a lower capacity.
Going back to the first post in this thread, does Grin define what they mean by a Cycle and what they define as "Useful Cycles" (aka Cycle Life)? I couldn't find these definitions, making their bar chart potentially misleading.
It appears many people quote
Battery University's 2010 post on the subject of degradation, but, as
this article points out, there are a few issues with BU's article, such as not incorporating starting SoC into its DoD chart. Starting at 100% and going to 50% has a different effect than starting at 50% and going to 0%, so a chart based solely on DoD is misleading. And there are data assertions without references in that article.
The definition of Cycle matters, too. For instance,
this article claims: "
100 cycles of 0.6 DOD does the same work as 150 cycles of 0.4 DOD." But, this is defining a
cycle using the first bullet at the top of my post here. That's not the way others define
cycle. As we see, Tesla is clear with its "full discharge-charge cycle" definition.
If Grin is using the top bullet definition, then its data needs to be adjusted to reflect the real work done. If going from 75% SoC to 50% yields a Cycle Life of
X top-bullet-definition Cycles (for some definition of Cycle Life), and going from 80% to 30% yields a Cycle Life of
0.6X top-bullet-definition Cycles, then you actually got more miles out of the deeper discharge.
25% battery capacity * X is less than 50% battery capacity DoD * 0.6X (.25X < .30X). Or, as stated
here: "At first glance, the 75-65 cycle seems to be the best for the battery, but you need to normalize it for work done: a 50% depth of discharge cycle does 5 times more work, 1000 cycles of 10% is 100 full cycles."
That last article has a table showing "Capacity per work done" and the results of that show that repeated 75%-65% use wears the battery out
faster than repeated 100% to 25% use - at least when you look at the total miles you accumulated!
So, my questions on the definition of Cycle and Cycle Life being bandied about are not academic.
Of course, in practical terms, one needs to charge at least as much as one will use in the day's ride. But, rather than thinking that charging to 100% is just bad, we need to remember that it's not the charge to 100% that's bad as it is keeping the battery at 100% that's bad. This is repeated in scholarly articles dating from
2002, and mentioned numerous times elsewhere, including in this thread. Tesla, for its part, engages in active battery cooling when you do the full (aka Range) charge, trying to reduce the degradation effects from that full charge. Our eBike batteries do not have active cooling.
For my part, I try to charge in cooler environments. My normal procedure is to charge to 80% starting about an hour after my ride and then do a charge to 100% the morning of my next ride. If I know I'm leaving early for a ride, I'll charge to 90% the night before. This way I typically have close to 100% battery for my rides, so no range anxiety, but the battery hasn't sat at a 100% SoC for very long.
