IggyBBR
- USA
Went for a quick trail ride yesterday, while rolling over a log I lost control (on some wet leaves and mud) and went over the bars. After picking myself off the ground I noticed that the tabs which holds the display snapped off. I manage to continue by reattaching the display with a few zipties to hold the display in place. When I arrive home, I noticed that the trigger was a bit loose. Upon closer inspection turns out it broke around the screw hole to the clamp. I wonder if I can find a replacement clamp and bottom display case without the purchasing a new set, since these two parts are still fully functional.
On another note, why can't the system run without the computer being attached? We should have an option to ride with needing the display attached and still be powered. Or possibly have the display mounted in place less likely to get damaged in an accident and rendering the system inoperable.
