- one imp. aspect that they've talked about is locking the ebike . Well what do you do with the DIY ebike battery ? You can't just leave it there on the top tube attached only with velcro. Even with screws is not secured. To remove it, gotta unplug a bunch of wires, etc..
I've got my battery caged in an aluminum angle frame, with foam all around it and a plastic bag on top. Half inch foam keeps one from touching the battery with your fingers. 12 screws hold frame together that take an 8" long driver to reach through the frame & foam to loosen. Elastic stop nuts so the nut doesn't spin off in half a turn, you have to crank it 10-15 turns while holding head still. Men twice have tried to remove a screw or two, while I was inside the store. Gave up. Actually taking four nuts off will remove the frame mount from bicycle frame, but even if you do that takes a nail puller to pry the 3.5" long bolts out of the frame. Those are double nutted, one elastic, so takes 2 wrenches counter torquing to even get the nuts off. One has to be thinned out with a grinder to hold the inner nut. Nobody has even tried to remove those. Takes 15-20 minutes to get the battery off; I only do that to leave it in the garage for freezing weather in the winter. 10-15 minutes to get the battery back on.
Wires- There are two, a red & a black, with insulated spade lugs to disconnect. Sex is reversed so you can't plug it in backwards. Industrial quality crimp lugs don't let go when you hit a big bump.
Battery frame could be cut with torch or grinder, but that would set the foam on fire. Big stink and display. Thinking of putting some magnesium ribbon in the foam to make sure the whole battery catches fire if someone tries that.
Controller with 8 wires is easier to steal, but it is a $35 part. Not worried about it. Rides under the seat out of the rain. I deleted the display: inaccurate, showed zero @ 30 mph downhill, and fogged up in the rain. Throttle has 3 color LEDs for battery charge.
Front wheel with motor could be stolen with 2 screwdrivers & a wrench. If I leave bike on street in bad neighborhoods I take 2 cables & locks so I can lock that too.
