fooferdoggie
you don't want to use a phone app to compare. my Apple Watch or phone is off a fair amount from my gamins.
I appreciate that information, I had assumed that the percentage was maximum useable so I reckon I have been very close to cutoff several times when I thought I was making it home comfortably. As I tell my children, assuming makes a dickhead out of everyone.It seemed that for my Delite I needed to select the smallest wheel circumference on my Kiox to get my GPS and KIOX readings to match.
Am I correct in assuming that if you use the smallest wheel circumference that can be selected this should give you the maximum actual speed before motor cutout even if potentially overestimating the distance travelled? For my Roadster selecting the smallest wheel circumference seems to overestimate the GPS distance by about 4%.
Also as another matter of interest I get motor cutout at 9% remaining battery on the e14 Delite and motor cutout at 5% remaining battery on the Roadster Vario. I understand the early cutout on the e14 is to ensure gear changing remains operational.
Cheers Stephen
the battery will cut off before it gets that low.Is it bad to actually drain the batteries entirely? I’ve heard mixed opinions on this question ....
